Shampipple
Ok. Just a few more questions again.
1. Draft Tube. The one from the shoebox engine won’t clear the frame and water pumps. What should I do?
2. Starter plate. Bottom bolts into oil pan- any idea if these are 5/16 coarse or fine, or am I way off?
3. Steering. My drag link was hitting the oil pan. I was going to modify the Pittman arm and or flip the linkage around weld and re taper. Are there any other magic solutions.
4. I found out the hard way I need truck exhaust manifolds. Are there any specifics to them? I’m picking up a set tomorrow.
Thank you all for getting me this far!
