334charlie
what problems can i expect putting an 8ba Flathead in a stock 32 ford roadster?
When I bought my basket case ‘32 3-window, somebody had boxed in a bent frame and welded in a Model-A front cross member. The project came with a rebuilt 59A engine with all the speed goodies. One of the things they did was weld the flathead motor mounts flush with the top of the frame rails. When I went to install the firewall it hit the intake before it could come far enough forward to line up with the factory holes in the frame. Somebody had marked the firewall with a marker and was getting ready to trim it away to clear the flathead. The engine and trans were bolted to an original ’32 cross member so it was not that the engine was mounted too far back. I started thinking, ‘32 Fords came with flathead V8s, the early blocks are physically the same size as the later ones so there should be no reason to cut anything. I removed the motors mounts pads which lowered the front of the engine and the firewall cleared the intake. I called the guy that I bought the car from and he gave me the number of the hot rod shop that built the frame. I called this guy and asked him why he had welded the mounts flush with the top of the frame. He said this was his first hot rod build using a flathead and he had looked at a bunch of magazine photos and it appeared to him that the mounts should be flush with the frame. I started looking at other ‘32 Fords using water pump motor mounts and most of the mounts were welded lower than the top of the frame rail. I hated that butchered and bent frame so bad I sold it to a kid, I told him everything that was wrong with it and he was still thrilled to get it, I was more thrilled to see it go away. I bought another frame that wasn’t too bad, this one still had its original front cross member but it had a piece cutout of it to clear a small block Chevy crank pulley. I was looking at those original motor mount pads and I decided to use the original ’32 motor mounts instead of welding mounts to my nice frame rails.
I bolted the engine in using original ‘32 motor mounts and brand new rubber biscuits. The water pump mounts definitely end up below the top of the frame rail. In this original position the firewall barely clears the intake, there is only about 3/8 of a inch space between the intake and the firewall. it is extremely important that you get the front of that motor at the correct height. I would not weld the mounts on without a firewall to check the clearance.
I started on a ‘32 roadster project and I robbed the 59A motor from the unfinished 3-window project. I have a ‘51 Merc motor to go back in the 3-window. My front cross member is already cut in the 3-Window so I don’t have to feel guilty about installing the Merc motor. I took a photo of my 59A motor, you can see that there is just about a ½ inch between the pulley and the cross member. The Merc pulley is going to move forward 1 ¾ inches, so that cross member lip would have to go. I took another photo of my 3-Window cross member which has had the lip trimmed away for a Chevy pulley. You would not have to trim this much for an 8BA pulley but you get the idea what has to be done
The late model truck pumps were designed so the belt would clear the distributor but they still have the early style motor mounts and the wide belt. The crankshaft pulley I will be using is a ‘49 Ford, I machined off the front pulley on a brake rotor lathe (see photo). The generator is a ‘57 Ford, it even had the alignment pin hole to fit the flathead generator mount. I can’t remember what I did to the front of the generator to get the fan mount, I’m pretty sure it’s the front of an old fan mount generator with the mount ground off of it, as you can tell by the dust on all this stuff its been awhile??? One of the neat features of the late model water pumps is they move the belt forward so it just barely clears the bend in the ‘32 motor mounts (see photo), on the earlier pumps the belt hit’s the mounts so you have to grind on them a bit. You can see in the photo that I have ground off the motor mounts on the pumps.
If I had a nice original ‘32 frame I would not use an 8BA unless I changed the cam, timing cover, distributor and water pumps so I would not have to trim the front cross member. I would also use original ‘32 motor mounts so I would not have to weld mounts to the rails. There is something magical about a pristine original ‘32 frame.
If I had a frame that had already been hot rodded and had lived eight of its nine lives as most have, then I would go ahead and weld on the water pump mounts, They are really a better setup than the ‘32 mounts. I would also replace the front cross member with a Model A to drop the front-end another inch.
If you still have to go through your engine take the crank to a machine shop and shorten it and turn it to take an early pulley,this solves the crank clerance problem and you don't have that ugly thing sticking out of the crank. John
The 42 thru 48 expanded double pulley can have the forward sheave lathed plum off. This is a common mod to make it work in an early single belt system. The snout on the crank should be near the same length and OD between the 59A types and the 8BA types. I'm not sure about the bolt threads though. The 8BA types are pretty big and they never used a crank ratchet bolt but it might be the same. If anyone knows for sure pass it on.
On the manifold situation you have to be mindfull that the early manifolds on the 8BA type block has no front road draft vent provision other than what was in the original 8BA intake manifold. A PCV valve set up would be a good idea in this situation. Also the fuel pump rods were different between years so a fellow would have to get creative if you wanted to run a mechanical pump set up. The rod would have to be the right dimensions to work correctly.
Kerby
