I am used to seeing, only one temperature port on the drivers side, yet these have two. What was the application and the years they were used. What was the extra port for?
Only the passenger side heater connection would be used. The driver side would be plugged or not even drilled. Heads are universal either side, with exception of some years (not sure which) used 6049 one side, 6050 the other side. No difference between them except for those bosses drilled or not drilled.
Except that if mounted on the other side, the water outlet would be on the wrong end. I guess that's what they make those looooong flex hoses for.
I have 2 separate gauges and two serrate sending units in my car, with the drivers side, having only one port.
Good funny.Except that if mounted on the other side, the water outlet would be on the wrong end. I guess that's what they make those looooong flex hoses for.
Another good funny.So you are saying it would be for a right hand drive car?
Alan, The heads depicted within this thread certainly cannot be swapped from side to side.
