8BA flywheel housing retainer and seal
1948F-1Pickup
Engine builder didn't install the item circled in red in the photo below.....
it was returned to me in a plastic bag. They did run-in the engine after it
was assembled on a test stand. No leaks or problems.
Any issue with not running the plate pictured below?
Thanks.
It's a '48 F-1 239 flathead.
There's no doubt it was on the engine beforehand when I gave it to H&H and
it was returned to me in a plastic bag when I picked the engine up, as I mentioned. Two short bolts are installed in the oil pan rail where this item
originally was. The engine was run on their stand before I picked it up.....
I'm assuming this piece is redundant.
I see the two seals are available from Mac van pelt. (8RT-6425 AND 8RT-6424)
Look at the photos of this oil pan for sale and you will see the bolt holes for that piece.
https://www.ebay.com/itm/393996212019?chn=ps&mkevt=1&mkcid=28
My 1950 Mercury stamped steel oil pan has similar bolt holes and bracket attached to the oil pan. As you can see the 2 bottom bell housing bolts go through those holes. Your situation may be similar. Hence, the piece you ask about is not needed.
