flatjack9
From what I remember, 8BA carburetors did not have a "spark valve" (that thing that looks like a power valve that screws into the carb base). That is on later carbs (2100's and 2110's). If you do have one of those, it should run fine, if it has the proper distributor vacuum.
Correct. The 8BA carbs do not have the spark valve in the base.
