8BA Distributor Disassembly
fredeuce
I am attempting to remove the breaker plate on an 8BA distributor.
The diagram shows a circlip however what I have found doesn't quite match the diagram.
Any tips here for the removal of the breaker plate?
(fredeuce)
Don't see the .025-.035 wire circlip in your picture so if it is not there the plate should just lift/pry off.
(you should be able to see the ends of the clip just under the top surface)
19Fordy, the distributor is a 1953 Ford Canada unit. All Australian Ford flatheads were sourced from Canada.
The link to the diagram shows the diagram that I mentioned in my original post. What I have doesn't appear to match the diagram.
On closer examination I have now found a very small round section wire circlip (0.030)" rather than the flat style circlip as in the Vanpelt diagram. I have been able to remove that and the breaker plate is now free to come off. Thanks to those who responded. Fred
i CAN SEE THE SMALL WIRE CLIP IN YOU PICTURE , I USE A PIC TO REMOVE . INSPECT ALL WIRING AND CARDBOARD INSULATION UNDER THE PLATE . INSTALL A NEW VAC UNIT FROM THIRD GEN FORD PARTS AS WELL.....WIRING INSULATION IS USUALLY DEFECTIVE ....................THE HEARD PART IS DONE ( REMOVING THE DRIVE GEAR )
Bubba,
You mentioned that the hard part is removing the drive gear. You are right about that and also the collar at the base of the distributor housing . Both of those pins were a major pain to remove.
I am thinking about replacing them with a 1/8"roll-pin instead .
Any views about the merits of doing that?
My 8BA Mallory distributer gear has been held in place with a roll pin for the past 30 years. No problems. A search shows that roll pins are commonly used to make installation easier and not damage your distributer shaft.
Bubba,
Yes i use a roll pin to replace the pins not a problem :D
