I looked at an 8BA block for sale today and wonder if its particular crack is repairable. I didn't have my camera so I'm sorry I can't post any photos.
The crack is in the number 6 exhaust port. The crack extends about 3/4 inch directly below the inside of the seat insert down the inside of the port. The exhaust seat insert itself is not cracked.There is evidence of pitting inside the port, suggesting water from the jacket has been getting in when the motor was operational. All other ports are smooth and rust free, as is the rest of the block. The block came from a running motor that when pulled was smothered in grease to preserve it. I understand that this owner had no reason to believe the block was faulty.
The first 8BA I owned lost an exhaust valve seat due to a crack from the outside edge of the valve to the cylinder which I understand is repairable - I've not seen a crack extending from the inside edge into the port. Any advice appreciated!
