Rollingmenace
Oh here goes my 51 is running an 8ba with a new bubba's distributor. After running a while and the motor is good and hot.. I go to shut the car off turn ignition switch off and the motor chugs a bit before finally shutting down... I know the ignition is powered off ... The timing pointer is set at 0 deg or pointer lined up with dot on crank pulley... I'm at a loss here, any suggestions??
