The one on the left side in the skirt near the oil pan? It is the return line from the by-pass oil filter back to the oil pan.
Nice looking paint job. the PCV system is simple to hook up and work perfect. Walt
Which specific PCV valve would you use? By that I mean from what original application?
A PCV from a 6cly over head valve Jeep work good. Walt
It will most likely blow the PCV out of the grommet if it is building up pressure and it will run poorly if it is bleeding off to much vacuum.
Don' t see how the valve in grommet would get blown out when there is an oil filler tube that gigantic!!!
R
