88 Ford Ranger
oldbugger
Old Rusty, as my wife calls it, is my plow truck here in Mi. Runs good for a 400 $ truck, except when it warms up. Its wierd, sometimes, not always, has a big bog when stepping on the gas, then quits, starts right back up and runs good for a minute or two, then does it again. I changed the in tank fuel pump, air valve for the intake, plugs, wires. It's a 2300 4cyl. any thoughts?
... except when it warms up. Its wierd, sometimes, not always, has a big bog when stepping on the gas, then quits, starts right back up and runs good for a minute or two, then does it again. I changed the in tank fuel pump, air valve ...
CARB or EFI?
AIR VALVE (?)
EFI, air valve, its attached to the air cleaner housing, "idle air valve"? sorry not up on EFI stuff, give a carb any day.
changed the one in the tank, and one on the inside of the frame, is there more of them
Those are the only two fiters. The pick up sock in the tank and the round metal filter on the frame rail by the high pressure pump.
Have you checked the fuel pressure when this happens ?
If I remember right it should be 32 PSI with the vacuum line on the regulator at idle, and 40 PSI with the vacuum line disconnected at the regulator (simulating wide open throttle).
Maybe scan the procesor for trouble codes too.
Sal
It sounds to me ... :rolleyes: ... as once it comes off the enrichment circuit (cold start), she goes lean.
I am a$$-u-me(ing) it is an EFI SYSTEM with a SGL THROAT THROTTLE BODY. It is EEC-IV OBD-II. The ECM needs to be scanned for any possible code(s).
Did you have a fuel pressure gauge when replacing the pump?
It idles fine at cold start but when the fast idle comes down she stutters?
Is the throttle body carboned up? There is also an IAC (IDLE AIR CONTROL) MOTOR on the side of the TB that will get gummed up as the PCV SYSTEM unloads there. Then you also have a COOLANT TEMP SENSOR that goes because the coolant is never changed and an AIR INLET TEMP SENSOR.
You can scan the ECM manually if you have the patience.
now you have overloaded me with info. Thanks I will see what i can figure out. On this one the idle air control is by the air cleaner, and i replaced that, seemed to help for a week or so then back to the same thing. I guess i should drive it more, but its not road worthy and it hardly snows here any more. ha ha
If I'm not mistaken, '88 was the last year for carburators before EFI took over in '89. Sounds to me like junk in the gas tank is bunching up around the sock and starving out the carb for gas, but once it is shut off, there's no more suction and the junk falls off around the sock, so the engine can start again, for a little while until the situation repeats itself. Either that or clogged fuel filter.
For refernece, I use those cheap clear-plastic inline fuel filters in both my jalopies and they never last longer than one year, even though I don't run them much anymore.
thanks Dave, the tank was new when i put the new fuel pump in,so shouldnt be too dirty. It is EFI, maybe an 89 never got the title. It is only driven on my property and not often enough
It is EFI, correct? This year had two pumps, one a transfer pump in the tank and the other, the high pressure pump on the rail.
Could also be a vacuum leak, EGR VALVE or possibly a fuel pressure regulator.
You actually need a FORD WSM to go through the DIAGNOSTIC ROUTINE before dumping any more $$$ on it.
If it is an '88, 2.3 it's a DOHC engine with a plastic intake manifold. The manifolds did crack, creating a vac leak, that usually won't throw trouble code. Sometimes you can find a vac leak with carb cleaner spray, just stay clear of the ignition system
In '88 the 2.3L Ranger was EFI, and the 2.0L 4 cyl. still used a carburetor.
This one is a 2.3L EFI, and yes the IAC was mounted to the air cleaner box with a hose going to the throttle body.
Sal
Yes, thats the one. when i mess with the IAC hose by taking it partial off the thing runs nice. thats why i replaced the IAC. but that was not the permanent fix, but makes me think i am on the right track.
... the IAC was mounted to the air cleaner box with a hose going to the throttle body.
oldbugger -
R U able to take and post photos? I surely would like to see how the engine is setup.
