8 volt batteries are easy to find at most battery supply places and are the same size as the one in my 1950 Mercury Sedan. Setting your regulator for an 8 volt battery isn't that difficult as long as you have a very accurate multimeter and do it correctly BUT
it pushes the hell out of your headlights, tail lights, radio and like dmsfrr mentioned check your cables. 8 volt batteries are easier to find than 6 volt head lights
I turfed the 8 volt after having a difficult time finding a battery maintainer and my battery got ruined from sitting dead. I bought a 780 CCA battery from a local farm and hardware store that is the exact size as what is used in my Mercury and BTW the 8 volt was the same exact dimensions as the 6 but had 4 caps instead of 3.
This is how I diagnose poor starting problems:
First of all we want to test how well your charging system is. You should have 7.1 volts and actually mine is charging at 7.5 which is a bit high but my new battery is not sweating or gassing or getting hot so I leave it alone. A sick battery is often wet on top with water sitting around the vents due to excessive gassing such as a sulfated battery. A friend of mine lent me a battery that was sitting dead for many months and being on a trickle charger for over a week brought it barely to life and even sitting not in use the top is always wet. I yanked it out due to carrying a 12 volt and booster cables in the trunk
. We will most certainly not flog this dead horse anymore!!! My God the car came to life with the new battery with all cables good with the charging system very good (why would I convert it to 12 volts and open another can of worms
) and I also knew everything was good except the battery
Also your charging system might have the correct voltage with everything OFF but can it handle the radio, headlights, heater blower motor (in cooler weather) all turned on at the same time or have the current to charge a battery fast after starting? The generator has a current regulator as well and this 35-40 amps might be low. Voltage regulators are usually quite reliable but they are controlled by a relay working against a spring. The tighter the spring, the higher the voltage and current. I have found these springs relax with time and sometimes need a tweak. If your current is a bit weak take a peek at your generator at the brushes to see if they are arcing quite a bit due to excessively worn brushes not being able to contact properly with the commutator bars. Gently pushing your regulator relay top arm with your finger tip to increase the spring tension momentarily will also give you clues if your generator is a bit under the weather as well. The voltage and or current will jump depending on whether it's the current, or voltage regulator relay when you do this to IF the generator can supply the demand if your regulator needs to be repaired or tweaked.
On the other hand a sweating boiling battery might be good but is being over charged such as constantly in the high 7's or low to mid 8's. Keep one thing in mind here, voltage regulators are temperature compensating and will always charge at a higher voltage when cold and as their temperature rises as they operate or the temperature outside rises they lower the voltage using bimetallic springs in the relays and when I set these regulators I always carefully place the cover back on not causing a short WHILE using a FULLY CHARGED GOOD battery, and place your engine on a slightly high idle as well so the generator can properly charge. Also another thing I failed to mention in this long story is if your voltage is slightly too low such as below 7 volts the battery will always be in a state of undercharged and will eventually deteriorate and become sulfated. A long slow low current charge will usually correct this if this is the case. The hotter the climate such as Arizona and Nevada, slightly lower voltages are required whereas the colder, slightly higher so your location and climate becomes a bit of a factor.
The current regulator is tested by placing a slight constant load on the battery with a carbon pile or all accessories on (providing they draw enough) with an accurate ammeter in series with the output of your generator or a clamp on inductive amp prob and the generator should be limited to 35-40 amps or your brushes wont't last but at the same time should be capable of supplying this current or the voltage will also be too low.
Your cables MUST be heavier like dmsfrr mentioned and what I do is I use the voltage drop method to test. PLACE one test lead DIRECTLY on your battery post, and the other on your cable terminal of the same post with your multimeter set to a low voltage. Next crank your engine with the ignition wire disconnected and read the voltage. There should be VERY LITTLE voltage, the lower the better. The heavier and better the connection the lower the voltage to the point of being a fractional voltage. If you have higher than normal, this indicates resistance causing your starter to struggle and a cable that is too light such as a flimsy cable meant for a 12 volt application or a corroded connection will show a higher than normal voltage. Don't stop there! Keep that same test lead on the battery post, and move the other test lead down to the next terminal or connection including both sides of the starter solenoid. If you have a poor solenoid IE burned contacts, and or cable ends yes you will have a voltage reading higher than normal. Keep going all the way down to the starter terminal. Do this for both cables positive and negative and your voltage should be very low doing this test. This test is for the condition of ALL of your cables and connections.
Okay your generator/charging system is good, your cables are good, but your starter is dragging it's ***, lets do another voltage drop test to see if the starter or battery is roached. Crank the starter again and see how low the voltage drops. If it really plunges, test the battery and by testing it, again make sure it is fully charged and place a carbon pile or load tester on it and see if this battery can do it's job. If your battery is very good but the voltage still drops quite hard your starter is probably drawing excessive voltage due to worn dry bushings causing the armature to drag, or a shorted armature or field windings.
On the other hand if the voltage barely drops but the starter still drags your brushes are possibly worn and cannot transfer enough power to the armature. A current draw test on the starter is also a good idea but if you cant get your hands on a load tester capable of doing this you have to improvise and get around this another way such as process of elimination IE ^^^^ (raise eyeballs)
Using a good meter which usually doesn't cost much and performing these easy tests usually prevents you from just throwing parts at your ride and needlessly throwing your money away.
Don
PS
Check your belt to see if it is loose
This should be step number one
