I recently was told by one of my club members that he was considering converting to a 8 volt battery. Are there many Model A owners that have made this conversion and is there a significant advantage to doing so?
All of the above is correct and there will be charging issues. The cutout on the generator cuts out around 7.4 volts or so. Not enough to keep an 8 volt up to par.
Using an 8 volt battery is a "band-aid" to cover up another problem. When all of the electrical systems on a Model-A are correct, there is no reason to go to an 8 volt.
I had an 8 Volt battery on my Model A once . It was always blowing out the bulbs .
I think you should have a 2 volt resister on each of the 6 volt bulbs !!
So that is another reason not to bother doing it!!
John Cochran
Eight volt is better than 6 and 10 volt is even better, but 6 or 12 will do the job fine. The problem is that you cannot get, over the counter, 8 or 10 volt components. If there was a demand for them it would be easy to make them but the standard is 6 or 12 (24 volt is probably coming soon).So I will either have to get some resistors, get a 6 volt battery, or change to 12 volt bulbs. Or change to 12 volt.
Why do these tales get started? 12v is better than 6v, so 8v must be better too. Sounds to me like 8v isn't quite as good as either 6v or 12v !
Oh well, I just discovered that either my generator or my cutout is not working either. Ah, the woes of de-mothballing a Model T after a 35-year storage. I sure wish the seller had kept his 8v battery.![]()
Charlie Stephens
