Ford coupe
79 granada with engine rebuild new bearings rings and lifters TWICE ..Engine startedout with what sounded like lifters so thinking i may have got bad ones replaced those to no avail. it now sounds like no oil up top but after removing top pan i find lots of oil at an idle and oil pressure is very good.. Now the only thing i did not replace was the cam and bearings as they seemed as new..It is not rod or mains i am sure but what sounded like a slight lifter noise when started is getting worse and i can now hear it in the car so getting a bit scaryIt is the 4.1 in line 6 by the way..So i will sign off and hope some specialist sees this and gets back to me...Thanks in advance..
