George49Ford
I recently had all new signal switch components put in the steering column. When I got it back the horn works with ignition off, but NOT with the ignition on. I've pulled the steering wheel but I rather not pull all the wires or the signal switch if I can help it. I also do NOT want to take it back to the morons who did this. They took 5 weeks and didn't a good job on the other things. Any thoughts or ideas would appreciated. Especially a fairly easy fix. And, for the record, the horn worked fine before I took it to those idiots.
Thanks for any input. http://www.fordbarn.com/forum/images/smilies/smile.gif
George Milliorn
George Milliorn
