When I did mine, Les was spot on, I followed his procedure and the play went from over 4 inches down to less than one.Here's what I found and corrected:The housing was bent and cracked where the rods exit, this caused misalignment from the top bushing to the bottom, the shaft was hard to turn. I straightened and welded it. The worm and sector gears looked fine but the bearings and bushings were all worn. The bottom of the steering shaft was badly scored. As Les suggested, I turned the shaft down on a lathe and installed an undersize bushing. The replacement sector bushings fit perfect and did not require fitting to the shaft. I used the oring and washer that the vendors sell on the sector which gets squashed between the box and the frame, no leaks. I used the extention tube in the bottom, fit ok with no modification, no leak. It's important to get the right combination of shims and gaskets on the bottom housing so you have no end play. I used a good flat file on the gasket surfaces, and a thin coat of RTV, no leak. I got all the pieces from Bratton's, all fit with no problem. I think this is better than converting to two tooth, JMO. She steers like new. There are many posts on this if you search and I an sure others will chime in, good luck.
