Rancho Deluxe
Hi Barners,
This is an assembly question about the 28-29 steering gearbox. I'm rebuilding one and none of my sources tells which way to orient the oil slot in the lower bushing on the steering column. It's the one just above the worm gear and upper thrust bearing. A slot lets oil past the lower rim of it to permit the bushing to be lubricated. In my case the old bushing had the slot oriented UP in the steering column, but I don't see how oil could get up there. I am guessing the rim slot should go in at the bottom. Here's a picture of it, and it can also be seen in the various parts catalog parts diagrams. In Snyder's and Bratton's it is labeled #14. What do you Barners think?
Thanks, Rancho
Thanks, Rancho
