KMBeers
I’m gearing up to rebuild a 7 tooth steering box for my 29 Tudor and my question is about the size of the reamers needed for the bushings once pressed into the column for both the steering gear and the sector shaft.
Since the steering shaft is using the same thrust bearings as the king pins I am wondering if the 0.810 reamer for the king pins is right? Also I can’t find any information on the sector shaft bushing size. The Les Andrew’s book only gives the clearance, not the diameter (unless I missed something).
I am trying to have the tools on hand for when I get started on my rebuild so any help is appreciated.
