my problem is that part #30 spins. The 4 bolt flange stays the the "ring" with the slot turns. (this ring is part of the bearing retainer on the 7 tooth box) The 2 tooth only has 2 bolts and the ring is separate as in the picture in this thread.
Is there a notch to hold it or do I need a spot of weld?[/QUOTE
Snyders doesn't appear to sell that anymore, Brattons have it #5379 -- $72.50, I did weld mine, if you do weld it make sure the notch is pointed exactly downward 90 degrees, before welding, if not the switch handle will not be centered at the steering wheel, just a few tacks will do, in addition be sure the oil hole at the top is pointing up, ------ I added a thin layer of epoxy around where it was welded it may leak a little.
