Don Cape Cod
Glens light switch trys to rotate because the lower bearing assembly, which includes detent to maintain its position, wants to rotate in the bottom mounting plate. A spare one also does the same. I assume this detent collar is swedged to the bottom plate and the rotation is a failure. Seems a spot of MIG weld should hold it in place and not intefere with mounting the switch. Comments anyone? Thanks, Don
