Lang's online ordering indicates that it does not have a 6 volt turn signal kit, but is limited to 12 volt kits. Does anyone know who is selling a 6 volt turn signal kit for a T?
Turn signal kits are basically all universal in nature. The Signal Stat 900 series was the most reliable set up back in the day. They are still available in the standard black case and the fancy chrome case. As was mentioned, the difference between 6 and 12-volt is mainly in the wiring, bulbs, and the breaker switch. If a person goes with a modern set up then the LEDs may work on 6-volt but they do require an electronic breaker since they don't draw enough amperage to get the old style current based breaker switch to work. The breakers are bi-metallic switches that heat up to open then cool down to close. If they don't draw enough current then they won't heat up enough to open the switch. The electronic ones have an electronic switch to open and close the signal circuit. Running incandescent bulbs, you need a good generator to run them.
If you want an easy set up then Mike's Affordable has an electronic kit for Model As in 6 or 12 volts. The want over $200 for it though. It should work on any old 6-volt car but a person has to find a good place to mount the little signals. https://www.mikes-afordable.com/product/A13311A.html
It was just a link to the push button electronic set up on Mike's Afordable. I can still link it on my phone but the web is full of land fill material.
