6V Starter
Ethan52
ok so today I went out and bought a 4 speed HD non synchro ******, Pressure plate, clutch disk and 6V starter for 175 dollars for the whole lot everything is in good working condition.
My question is when you're hooking up the 6V starter to 12 volts do you wire it as if it were a 12V one or do I have to do anything special to it? would rather ask first and not have it end up like when I did my first Generator to Alternator conversion :rolleyes:
Other than feeding it with a 12v relay, hook it up like a 12v starter irrespective of whether you're running positive or negative ground. My 6v starter been on 12v negative ground for years.
Jack E/NJ
