6v fuel pump for carb draining....
tonydennisadw
still cant fig out why carb drains so heres my ? got a 6 v ele fuel pump low volume will it work ok if i put it next to fuel pump this old man will prob have gas everywhere if i try to hook up near gas tank...once it sits for 4- 5 days have a lot of cranking to get gas back up thanks dennis
I have the same problem, I am going to ask the Stromberg specialist, carb shouldn't drain down.
electric pumps are better at pushing fuel than sucking it. I've seen them mounted on the firewall and said to work, but all the manufacturers recommend mounting them close to and below the fuel tank. You can try it there and if it doesn't work you know what you have to do.
To the O/P. It looks to me that the problem is that your carb "drains down" over time. Is that the correct reading of the problem? If it is, then you should concentrate on solving the problem rather than mitigating the symptoms. You don't say what kind of car or carburetor you have, but if it's a "94 style", I'll bet you have power valve leakage problems. Take the top off the carburetor and fill the float bowl with gas. If it's down substantially the next morning (or maybe even dry), you have found the problem and can proceed to correct the actual problem.
Where are you located in sw Ohio? What make & model car are you referring to? I would be glad to help you install the electric fuel pump when I return home in the spring. Pat
Just mounted a 6 volt pump on firewall because I couldn’t crawl under car,works fine and regular pumps pulls thru electric,no problem
Electric pump puts up to much pressure so just use it to fill carb and emergencys
Here in the UK you can get SU pumps, and specify 'push' ie tank fitting or 'pull' ie firewall fitting, 6 or 12v. Running one with no problems. Just need to fix the draindown, reckon Tubman is right, it's the power valve.
I'll throw my two cents in for the leaky power valve the '94 carb. I have heard that some replacement parts fit poorly, so check around.
Do you intend to use the fuel pump as a primer only, or continuous operation?
If you intend on continuous operation, can I suggest you consider a oil pressure cut out switch in the pump control circuit?
I prefer an impact switch, the reason being that if you were involved in a collision and the engine were running/racing, the oil pressure switch will not shut off the fuel pump.
thanks to all for help and Pat/ohio we have had a trailer in wilmington at kirkwood for over 40 years i am in cincinnati east the car is 52 ford flathead is 3rd carb ive tried think this one is a holly
Tony, i too have a 52 Ford and my problem is NOT a leaky power valve, but heat "boiling" the fuel in the float bowl. I have an elect. pump at the tank with a pressure regulator & manual shut off under the hood. I use the elect. to prime if needed & ward off vapor lock.
WORKS LIKE A CHAMP. m
fortyonerag primer only runs great when fills up ok mfirth too cold now to fool with it soon as gets in 50ties with sun can handle it this engine runs cool unless extreme heat like last summer but neveer a boil prob
I would pull the carb, you can take it off in just a few minutes. Fill the bowl up with fuel to the correct level and see where it leaks from, if it is leaking. I've seen carb bodies crack and power valves leak.
I don't see how the fuel could siphon back into the tank. The needle and seat are at the top of the float bowl. If the fuel level in the bowl dropped just a little the float would lower and the needle would lift off the seat exposing the line to air. That would prevent any siphoning from happening. I'm not sure but I think the needle and seat are completely above the fuel level in the bowl. Its exactly like your toilet bowl valve. I don't think siphoning is possible.
It does not take gasoline very long to evaporate. Especially now that it has 10% ethanol in it. If it sits for five-days vented to the atmosphere it could just be evaporating through the vent tubes. You could plug the vents and after five-days remove the plugs from the vents and see if starts right up. You could also remove the carb top and see if the bowl is still full. Modern carbs have vents that close when the engine is "not" running so the fuel can not evaporate.
I have a 1966 Shelby GT-350 that I never start. I've driven it 100 miles since 1982. I've been in flathead/hot rod mode for years since I burned out on the Mustangs. Maybe once every two year's I decide to start the Shelby up and take it around the block. When I start the car it immediately starts to flood out because the power valve has rotted away and fuel can flow straight through hole in the diaphragm and into the engine. I now know if I want to start it I will need to take off the front bowl and stick a new power valve in it. I probably get one-mile of driving per power valve. Afterwards, I always tell myself, this is stupid I'm going to start this car up at least once week but then it never happens. Too many projects.
If this was your only car you would be driving it nearly every day and the fuel would not have enough time to evaporate. Ideally carbureted cars need to be started every couple of days. Carburetors do not like not being exercised. We are spoiled by fuel injection. There are no vents in this system. The pressure can be held in the line for days. The fuel pressure cannot drop as long as the check valve in the electric fuel pump holds and the injectors are not leaking. That fuel will sit between the fuel pump and injectors under pressure forever, ready to instantly start spraying with the first revolution of the crankshaft. Its best thing that has ever happened to automobiles. But its not nearly as cool
as a Stromberg carburetor.
If you had a bad check valve in your mechanical pump the fuel might be able to drain back into the tank but that would only be the fuel in the line up to the carb but not the fuel in the float bowl.
A little tip if you have your carb off. If you put a thin layer of white lithium grease on both sides of your carb's base gasket it will not stick to the carb or intake the next time you remove the carb. If your pulling carbs off a lot, you don't want to be scraping off gaskets, its a real time saver. Plus your not tearing up your nice machined surfaces with a putty knife. We rebuilt Holley 4V carbs on the big Ford trucks at work so often that we started greasing the base gaskets because they would get baked onto the intake. You could not scrape them off we had to grind them off with a Roloc metal conditioning discs. You don't want that stuff going in the intake, the abrasive on the discs will destroy an engine. It took longer to get the gasket off than it did to rebuild the carb. Same with the bowl gaskets, we had to scrape them out with a little screw driver.. Those we sprayed with silicone spray to prevent them from getting baked onto the carb. It did not hurt a thing, the gaskets still sealed perfectly and you could rebuild the carb the next time a lot quicker. I was taught this trick from a 1960s-1970s Ford dealership's, carburetor rebuilder. He left Ford to come work with us.
flathead fever well this is the 3rd carb on there and still drains however i have another 52 flattie that has sat for at least a month and always starts right away.....dennis
With the carb. off the engine and set up at a level consistent with being mounted in the car. Fill the float chamber to its operating level with mineral spirits (or equivalent).
If there are any leaks, they should make themselves visible.
Carb inlet is at the TOP of the bowl, so fuel cannot run back into the tank. If the bowl is draining, it has to be either evaporation or it's leaking down through the power valve.
