Tak28Tudor
Vehicle: 1948 F1 Flathead V8
I am the new owner of a 1948 F1 truck. I have noticed that the Battery Gauge reads "Discharge" when the truck is driven. The truck has original style generator and i'm constantly having to charge the battery and the truck lacks power when given more than 3/4 throttle. However, I have discovered that the 6V battery has been connected with Negative Ground. Someone connected the battery cables backwards (from OEM). Could the polarity be incorrect on the generator which has resulted in "discharging" instead of charging and could the coil be not providing full capacity too? My thought was to change the battery cable back to Positive Ground and see if that fixes the problem. There are no aftermarket add-ons.
Thanks for the guidance!
Brent
Brent
