Fortunateson
I have my Dad's LTD which he ordered mainly for towing our 22' trailer. I've been saving this for a long time and have acquired a number of smaller nos trim and a Ford stamped NOS 1/4 panel for a sedan.
Anyway I rebuilt the carb after a small backfire and replaced the plugs, points , condenser, and coil. Engine cranks over but won't catch. I haven't found a ballast resistor that I might replace. A friend said they didn't use a traditional restor but a resistor wire from the ignition switch. True? Any other ideas to get the engine running? I didn't remove the distributor so that can't be the problem.
After I get it going I'll remove the gas tank and get it cleaned out as well as going over the brake system. From there body work and beyond...
