I'm trying to replace a 1969 429 oil pan gasket. I can't seem to remove the oil pan because it gets wedged between the counter weights on the crank and the crossmember. I've tried to rotate the crank and lift the motor without removing the motor mounts. Has anyone ran into this problem before and if so what is the easiest way of doing this?
