eystein
Actually you would need to install their cover and mark all seams to be sewn as well as cut lines with chalk, then remove the cover and cut, sew, etc. Obviously that is more work than most folks would care to attempt. It can also be problematic in some cases. some of their fabrics stretch too much and the stretch is relied upon to get a respectable fit. Additionally, those same fabrics would have to be sewn carefully with a moderately fine stitch at the binding so the loose weave of the fabric won't just tear out. Originally these fabrics were laminated to a layer of thin cotton muslin on the seat facings (or skirt) only which made the fabric strong and resilient. I did just that on the Coupe below 20+ years ago. I had located some old stock grey check and chose to duplicate Ford's version in every detail possible. It's pretty cool to be able to do silly things like remove the cushion to get at the tools and still feel like it's the "real thing".
Marco,
What material and Color would the edge binding be for a 1930 fixed seat Cabriolet ?
I am thinking that I might use the same brown simulated leather binding that LB-B supplies to finish the T14-GT top.
How did you laminate the muslin to the fabric ? Spray glue ?
Did you laminate the whole fabric side piece before sewing together with the cushion top material ? I guess that it is futile to do this after I receive the kit from LB-B, as I would want the muslin to be stitched together with the fabric at the seam with the cushion top cover and go all the way down to where the sides are tacked to the frame ?
