68-C Top Wood
lfg
I am going to need the wood top bows for a 68-C. Would you recommend Classic Wood in NC or Cuble Ford Wood in UT or another supplier ?
Larry
Classic Wood is THE VERY BEST !!! After pre-fitting my wood kit, I disassembled it and gave it two coats of tongue oil to seal it. After letting it dry for a few days, I re assembled it. This was on a 160-C SW Sedan.
Bruce Davis a400usa@nccn.net
No instructions, just wood pieces in a box. Makes you have to think. All his wood is made from original patterns and not per the drawings. So everything is real close but still needs some minor adjustments.
Fitting the wood in a Cabriolet takes a little more time than an all steel SW Sedan. The form of the body moves more in a CABRIOLET than the fairley ridgid body of a SW Sedan. Take your time in the fitting. The final adjustments to the top bows will be made when you get your top kit.
