hi Frank, the picture that Stephenorf shows is a very common location for the
cable exit hole on the older 'stangs I have worked on.
However, my 2+2 fastback that I ordered new in '65 has a 4 speed, and the
speedo cable exits on the upper left corner of the tunnel, and my cable runs
across the upper part of the trans, and installs on the passenger side of the
****** tail shaft.
My friend had a '66 'stang with a 289 automatic, and his cable had the exit
hole in the same place as my '65 4 speed car. (left upper corner of tunnel)
I found an old crusty picture of a early stang, and I colored in a blue dot in
that upper left corner to give you some idea.
The automatic cables are shorter than the 4 speed cables, as they install on
the driver (left) side of the ****** tail shaft.
Most of the new cables I have installed, have a thick round foam gasket on
them, so if you have to drill a hole, then get the cable first so you can drill a
hole just a little smaller, so the foam gasket can make a good seal to keep
out dust and/or any water that can splash up there.
Here is that picture I took and then colored in the blue dot, and actually
the
hole could be an inch or two higher than that.
Click on picture to Enlarge
