Hi folks. I believe my fuel pump conked out today. To make sure, I thought I'd check some things out. I disconnected the line to the carb, and very little to no gas is getting through, though there is a spurt now and then, but hardly any as time goes on.
Just put a new metal fuel line from the tank (which is NEAR NEW) to the fuel pump. The fuel pump doesn't look all that old, but I don't know. I checked carefully and there are no kinks in the new line, AND the car ran good for 15 to 20 minutes after the new line was installed, so I don't think that's the issue.
The engine (and presumably pump) are a 390, but out of (I think) a '67 Mercury. It's a 2 bbl carb. The fuel pump looks just like the one Mac's has listed for a '64 to 66' T-Bird, though. Here's what Mac's has:
Question: Is that elongated enclosure at the bottom of the pump a filter of some sort? (My Mercury 352 fuel pump has no such enclosure.) If it is, in fact, a filter in the pump, could the filter in the pump be clogged, and if so, how could I unclog it???
I checked the filter I have between the pump and the carb and it seems fine, or at least clear enough to let gas through. Thanks for any help.
Jim
Jim
