callbald
I always leave the keys in the car. Got in the car and found the GEN light on with the ignition key in the off position. Started the car and absolutely not charging.
Voltmeter showed the battery level of 12 volts with no deflection when I rev'd the engine. (When I found the GEN light on, I did not think to look and see if the voltage meter was reading anything because it shouldn't if the ignition is off)
Earlier today I drove the car a good 40 miles and the aftermarket voltmeter was showing charge of 14 volts. I always glance at the gauges when driving and voltage gauge as usual was reading 14-15 volts.
New voltage regulator and solenoid gauges installed about 3 months ago. I replaced them when charging was low at 12-12.5 volts.
