callbald Senior Member Feb 26, 2018 #1 Can the Driver door remote control (ford base # 6221819) be repaired? The inside door handle is attached to the remote control and the tension spring is broken. OR where can I buy one. Thanks Rob Attachments IMG_1728.jpg 70.3 KB · Views: 15
frank long island Well-known member Feb 27, 2018 #2 the springs should be available ck with macs bob drake concours ect
rotorwrench Well-known member Feb 28, 2018 #3 Whether riveted or spot welded, they can be repaired with a new spring.
