64 F100 steering box
64steve
Hello everyone!
I have a 64 F100 and took the steering box out in order to rebuild as i had extreme play in the box , i found out my adjustment plate had broken causing the pitman shaft to walk , alongside this the pitman shaft is worn and my steering colum is worn so bad the piece where the shifter is tack welded onto it broke off so if anyone can share and try to see where i can locate these parts it would be awesome! nos , used dont really care and if i can find a complete box that i may be able to salvage parts off id be interested also. Heres attached photos of what im talking about
Did you contact the re-builder suggested in the other thread?
REDHEAD (or similar vendor) may have an exchange or may have the parts to save yours.
If doing yourself, do you have the FORD WORKSHOP MANUAL?
About where are you located in MD? I am just below Hagerstown.
  • STEERING - 1964 F100 4X2 MS _3 - 1964-1972 TRUCK - ILL - Final Issue.pdf.jpg
I did , we talked and helped me adjust it before taking the steering box out but he said he doesn't do these and sadly cant point me in the right location , but i may try to call them up and see if they have anything , but yes i do have the ford workshop manual and my boss who's rebuilt many since he's had his shop since the 70's so his experience is great. I'm also located near Annapolis Maryland about an a hour and a half from you
wanted to give an update and thank you , called them and while they didn’t sell me a complete rebuild kit they atleast sold me the adjuster plate which was enough to take care of 90% of my excessive play , they were great and understanding and i want to thank you again !
