Smokinjoe3
I acquired a 63 Galaxie recently. Previous owner did a front disc brake conversion (booster with dual master cylinder that looks like it is from an early 70s mustang, drilled slotted discs with braided lines). My test drive of the car went well and the brakes were solid. Now that I've owned the car for a little bit it felt like the brakes were dragging. Sure enough, I jacked the front and the wheels turned, but there was significant drag. I unbolted the master from the booster thinking that the rod was adjusted too far, but that didn't release the brakes. I cracked the bleeder at one of the calipers and they released. Thinking it might be the master cylinder, I picked another one up at the local parts store from a 72 mustang with front disc brakes. Changed it out and bleed the system well, but still holds pressure. Interestingly, the car does not have a proportioning valve, but stopped well without locking up the rear. Any ideas on what to do? Why is it not releasing the pressure?
