- City
- Baton Rouge
- State
- LA
- Price
- 42,500.00
Restored in 07 with only 300 miles since. Real g code 406/405 4-speed sunliner convertible. Fresh correct 406/405 Survival motorsports engine with dyno time only. Stock appearance engine with scat 4.25 crank. mod solid lifter cam. made 450/510 torque on dyno. Fresh davids 4-speeds 62 t-10(not original to the car) custom built with micrpolished nos gears and rebilt/rechromed shifter(2200.00). .Original kelsey hayes hubs on widened 15x7 15x8 new outers. 3 original kelsey hayes wheels.build sheet. Offered here first as i want a ford guy to get it. engine and trans going in the car as i write this. pm or email questions or more pics.
FE shop cleanout. 63 406 crossbolted block with pro stock engeneering main caps. very nice ready to build block with cam bearings installed. 2500.00
Early galaxie t-5 5 speed conversion. angled crossmember so shifter is in the stock position, bellhousing, driveshaft, shifter housing with hurst handle. no trans. 400.00
65? 390 40 over shortblock with stock 406 solid lifter cam. approx 300 miles. 600.00
62 t-10 core. bellhousing and shifter linkage no handle. 400.00
stock 4-speed conversion parts and floor hump. a few misc parts and trim. If you buy the car ill throw in all the parts.
chris.emory@vascularlab.net
