have a 61 galaxie with a 292 y block , one side exhaust is running cold , the passenger side .
about 1/5 the heat and pressure of the other side exhaust pipe ,
engine is running well and firing on all eight cylinders,
has 2 separate exhaust pipes from the manifolds to the rear . no crossover pipe
have checked the muffler for blockages , not blocked.
the heat riser valve on the passenger side has been removed as was leaking .
have checked valve clearances , all ok .
checked timing .
have done a compression test to check for blown head gasket , all cylinders between 115 and 125 .so assuming it is not blown between 2 cylinders ,
checked for inlet manifold leaks , no leakage found .
fitted new plugs , leads, cap and rotor .
anyone had any experience with this, or any advice on what else the problem could be .
thanks in advance
checked timing .
thanks in advance
