A-Jay
Guys, this may sound dumb, I want to replace the rear end and transmission lube. Is it best to do after a drive when all is warmed up, what about the drain/fill plugs is it OK to try to remove hot ? Also what is the best tool to use to remove the rear end plugs, they are a square hole and just a little smaller than a 1/2 extension ?
