'60 ford 292 ignition points/ condenser
fordor41
I have looked hi & low trying to find P/N's for Motorcraft points & condenser.
I've found standard parts and off brands but no Motorcraft. Any info or recommendations if no Motorcraft available -thanks
POINT SET - B8Q 12171-A (DP-12)
- 1957 thru 1974 V8
COND - C9AZ 12300-A (DC-13-A)
- 1959 thru 1974 V8
FORGOT -
The PN's in parenthesis are MOTORCRAFT and that is how you would SEARCH for them new on the net.
Either new or NOS are available - FOMOCO-AUTOLITE-MOTORCRAFT.
I have some N.O.S. Motorcraft and some other N.O.S. U.S.A. made brands....
Always best to simply call me --- Craig --- 516 - 485 - 1935.....
Do you advertise anywhere or have a inventory list available? It would be nice to know what you are hiding up there ... :D
every time I checked DP-12 & DC -13-A it comes up with "will not fit your car". Have tried multiple web sites. I thought most ford engines took the same points no matter what(Y-block, SBF, BBF). Actually I bought both last night then got thinking to check with different dealers to see if the ones I ordered were correct. That's when I got confused!
... every time I checked DP-12 & DC -13-A it comes up with "will not fit your car". Have tried multiple web sites. I thought most ford engines took the same points no matter what(Y-block, SBF, BBF). Actually I bought both last night then got thinking to check with different dealers to see if the ones I ordered were correct. That's when I got confused!
Yours is a 292, if I could remember, correct?
If so, that's them.
