32BBflathead
It's not a ford or a vehicle so feel free to delete this if it is not permitted for any reason. I've got a farmall c I'm trying to get running, it's still a 6 volt system. The battery seems to be going down exceptionally quickly when cranking. The battery will still show 6 volts but wont even be able to turn the engine once. Even when it is still turning it fast it doesn't do a good job, it won't spin consistently. The reason I'm posting this is I believe it might have to do with the 6 volt system, is it finicky or anything in particular? The battery is an older so I think it may be that I just don't understand why it's going down so fast and still showing 6 volts, even with the charger hooked up. The tractor has a magneto.
