6 volt turn signals ????
Paul...are you saying I could use a 12v turn signal switch for my 6 volt car ? I have a turn signal switch for a 12 volt car...I would have to remove the 12v bulb and replace with a 6v bulb....
Why do the vendors who sell these item specify 6 or 12 volt when purchasing ?
The designation likely involves the flasher provided as these are voltage specific.
I believe that the 12v unit I have is sold by every vendor for $25. or so...the wires that are coming out of the unit are 18 gage, would I need heavier wires for the 6v ?
Very good point; 6V would require heavier wire. Another option could be to find an original accessory unit produced by Ford for ‘49/‘50 Model year. I installed one of these recently on my ‘36. Still haven’t incorporated the self canceling feature yet; gotta do some more engineering to get that going, but the unit itself works great. It did require that I run two additional wires over what’s shown on the Ford instructions. One wire from the stop light switch (hot side) and one wire to the right rear. Other than that I purchased the repop wiring for the switch, the repop front crossover wire and the repop rear wire (from switch to LH taillight). I did have to adapt the indicator bulbs to a couple of green jewel lights I found on the internet. Installation was straight forward and it works great.
Check the Model A vendors... Berts, Mikes Affordable, Brattons. They all have 6 volt kits. Chap
The brake/turn signal filament wiring should be at least #16, but #14 would be better.
I have seen several applications of '60s VW turn signal kits (6 volt), mounted in early Fords. When the housing is painted the same color as the steering column it looks factory.
Tom
Tom
I've used the VW turn unit on several occasions. They work excellent and can be painted the same color as the column. That switch was used on the bugs and the buses.
Another option is the toggle turn switch from American Auto wire or Kwik Wire. It can be mounted under the dash where it is basically not noticeable.
Anyone able to post a picture of what lights are used on the front of the car and a picture or good description of how they are mounted ?
I have twin taillights in the rear of the car so am planning to hook up the directionals to those. I also am thinking of a 3rd light using suction cups to hold the 3rd light to the rear window and the directional would also work on those....all ideas and comments are invited.
I installed flashers on my 41 after having problems (particularly at night) with other drivers not understanding my intentions. The car is 6V positive earth.
I used a commonly available 12V turn signal unit. The wire gauge does not seem to be problem with the load. The turn signal units seem (at least those I have seen) to come in 7 wire and 5 wire units. The 7 wire units are configured to provide flashing brake lights. The 5 wire units are used when you have discrete lamps to flash. The connection diagrams will come with whichever unit you select.
If you are running positive earth you will need a compatible positive earth flasher can. I used a BV535 3 prong flasher can. You can use two prong cans, but there is a little extra wiring to be done for the pilot light.
I have flashing brake lights in the rear. In the front I replaced the single element park light globe holder with a two element globe holder (like brake lights) and have a discrete flashers. This way I still have park lights, but the car looks stock.
The use of front lights depends on the year of the car, From 1940 up you can use the parking lights. From 1939 back you can use the parking lamps in the head lights, but they get wiped out when the head lights are on. I prefer using a vintage set of fog lamps on the front of the early cars. You can't miss them when they flash.
I used United Pacific turn signal clamp-on purchased from Summit Racing. Part number UPD-5007R for $31.99. It also required a 6 volt flasher part number UPD-110252 for $12.99. Easy to follow directions for wiring with my positive ground. Simply tighten the band clamp on the steering column. Well constructed and fit my 1932 column shaft.
I ended up swapping out the internal indicator flash bulb to a 6 volt equivalent so I could see the light. Since it doesn't have any self-cancelling cam, I also installed a stock GM headlight buzzer to remind me wired to the flasher...
https://www.summitracing.com/parts/upd-5007r
https://www.summitracing.com/parts/upd-110252
Signal stat was a popular name brand in add on signal light kits back before signals were common on vehicles. I've got a couple of them on fifties IH trucks. Also salvaged another one from a rusted out GMC. Maybe some day I will figure out how to install one in my 52 Merc.
I use a Trucklite/ Signal Sat 900 switch that clamps to the column. Made my own colour coded loom and ran the wires inside the the chassis rails to all four corners. Got a park light conversion pigtails from C&G so I could run a dual filament bulb to incorporate the front turn signals. As amber turn signals are the norm here in NZ and no one would take any notice of little red flashing tail lights I gold hold of 2 period Ford back up lights and converted those to turn signals by putting in an orange 6v amber VW bulb and cutting up a clear orange kitchen cleaner spray bottle and placed that behind the bulb to give a better spread of light. For the flasher unit I used a Tridon/Novita LL535 which is a 6v unit and USA made, don't use the Chinese equivalent that sometimes come with kits, they are crap. I got my US made ones through Rock Auto. Those Novita ones make a good loud click too. I mounted mine on one of the springing clips designed to hold cylindercal objects which I attached behind the dash to one of the screws that hold the radio speaker grill in place ( I don't have a radio). Best thing I ever did and I feel safer driving the car. No one knows what hand signals are today...people thing you are makeing rude signs at them.
GB
