Here's a 12 volt one that you could run down to Radio Shack and pick up for under $5.00. It would probably work with 6 volt since it doesn't take much juice to activate the electromagnet for a relay. The secondary (switched) side of the relay doesn't care about voltage since it's just a switch. If it doesn't work, just take it back. http://www.radioshack.com/product/index.jsp?productId=3020762
I just bought this 12 volt relay from Radio Shack and it works fine on 6 volts. Just thought someone might like to know.
Low voltage will cause it to heat up and burn out sooner if it works at allI just bought this 12 volt relay from Radio Shack and it works fine on 6 volts. Just thought someone might like to know.
good find (Y)Here's another option: The Bosch relays were a little too pricey for me so a google search turned up these identical SPDT take-offs for ~$3.50 ea. They look and mount just like the Bosch units.
Tyco Electronics 0-1432873-1. They're 6v, 40 amp low resistance relays and you can get them here:
http://www.newark.com/jsp/displayProduct.jsp?sku=21M4888&CMP=KNC-G-SKU-TECONNECTIVITY
I use two of them on the grey coupe... one for the electric fuel pump and one for a universal 6v wiper that I sometimes swap out for the vacuum unit on cross country trips (one advantage of not having a headliner installed)... Both are wired with switches off of the ignition circuit so everything shuts down with the key. I've been using them for almost three years now w/ no trouble.
Following Supereal's recommendation, I made a headlight relay from two 6v Echlin (NAPA) Solenoids, ST541 (one for high beam and one for low). It works great.
That's the approach I like, except I use a continues duty relay.
Yep, told me the same thing as have several other people. I still prefer the continuous duty relays. However, you can most likely find the interment duty ones cheaper if cost is an issue.I asked Supereal about using the ST541 as a continuous duty relay. Said he's used them for years with no problems.
Jerry
Wonder if this would work.
Bosch 0332204001 6 Volt relay
Pin 87A low beam N/C
Pin 87 High beam N/O
Pin 30 Headlight switch
Pin 85 Bat positive
Pin 86 Dimmer switch either side, other side open.
Bruce
"Battery power on 85/86 and the dimmer switch on 85/86 would be providing power to both sides at the same time."
Low beam circuit 87A is open when the dimmer switch is toggled to High completing the circuit 87
Bruce
