6 Volt Positive ground Alternator
When you hook up a 1 wire, Positive ground alternator the out wire on the alternator connects to negative battery terminal. Is the correct, Thanks, Steve
If using the stock wiring harness the alternator "out" (-) would be routed to the light switch and horn also.
