6 volt pos. To 6 volt neg., ground
jayvee34
Just finished reading an article by Randy Rundel on converting 6V pos.,
to 6V neg. Has anyone or know of anyone who has done this? What
would be the advantage of doing this? I know maybe a couple. According
to Randy it is a easy and simple thing to do. The problem I see with it
would be if you are running a 6V positive ground alternator it would expensive to change over to a negative ground one, He didn't mention being able to
convert the alternator.
The only way I'd change over to negative ground would be if I was going to a 12 volt system. Otherwise, leave it alone.
OK, what are the benefits?
You can get a inverter to run 12 volt accessories, e.g. radio,
phone charger, GPS, and a few other things. If you went to 12 volts you would have to change your lights and maybe starter, and generator or alternator.
Personally, I like mine as it is. Just thought it was interesting that someone could come up
with such devises.
