6V generator uses the cut out as a one way valve, so it should not allow electricity back thru the gen when not running... The battery controls the output voltage...
Hook up the gen cut out to the system, should not spark... Start the car, check the voltage... 3 brush takes a while to bring the battery up, so be patient... Adjusting the 3rd brush needs to be done after the car has run a while, adjustments are not felt imediatly... AND, mark where thing were before you start doing anything...
Karl
