Exactly what make or type of gauge are you asking about. Original 6 volt gauges require a voltage dropping unit to reduce the 12 volt supply to 6 volts if you are using a 6 volt gauge on a 12 volt system. The sender unit will function with the gauge on either voltage. Gauges need to be matched to their original type sender units. Just any old sender unit is not suitable. Regards, Kevin.
