pdora
I took delivery yesterday on a 1930 Tudor. As I began inspecting it I discovered that it is wired 6-Volt, negative ground!
Because I don't have access to the previous owner I would appreciate any comments from the Barn.
The lights (all incandescent) work OK; they don't care about polarity. The same goes for the starter motor and the electric windshield wiper.
The generator has been replaced with an alternator (pictured).
At rest the electrical system measures 6.2 volts. When running it measures 7.5 volts while charging. Thus, the alternator seems to be functioning properly.
Whoever did the conversion took care of the ammeter polarity (it goes down, not up when the lights are turned on).
I hope he saw to the coil polarity. It seems to run OK.
My surmise is that all he had available was a negative-ground alternator and proceeded accordingly.
Because I intend to convert to 12-volt negative ground in a few months, I am inclined to leave well enough alone.
Some questions:
1. Is this all that unusual?
2. How can I be sure the coil polarity is correct?
3. Are there any other considerations I have missed?
Thanks.
Some questions:
Thanks.
