So, after changing plugs, wires, oil and filter I tried starting my 49 F3. It cranked slow as it has since I got it. It actually never started without being pulled even before I bought it. I had some smoke coming from the starter relay or in that area. I changed the relay with a new 6 volt and also changed battery and starter cables with 1/0 wire. I tried again but absolutely nothing. I found the wire broke off the starter button. I changed the button with a new one (same thing) and still nothing. I tried a new wire for starter button, same story not even a click. My battery is positive grounded to engine head but I found no grounds on the frame or cab. Can someone tell me how to properly ground this truck? I think my issue here may be due to poor grounding. Any thoughts?
