Hi gents...
Over the weekend I was checking the voltage at my headlights. Suprise suprise I had 5.6 volts (not running) at the end of the cowl wiring to the headlight and 4.5 at the bulb (through the Bob Drake kit). It is easy to see why when you compare the quality of construction and the wire diameter. Regardless I ordered headlight wires from Tyree Harris and am searching for NOS bulb holders to solder to.
Note: not a slam on Bob Drake just commentary. Probably less of a problem on 12V.
