6 volt battery
46fordnut
i cant remember what a 6 volt battery full charge should read on a meter. mine read 6.3 volts. thinking maybe little low. any help would be great. thank you in advance:o
I believe it is 2.2 volts per cell, 6.6 volts would be the max possible, slightly less real world.
If it doesnt drain from sitting without load and stays in that area seems fine to me.
Need to load test it to see if you still have some cranking capacity to be real sure about the condition.
