Is there a difference between 6 volt and 12 volt amp gauges? They put a cheap after market amp gauge on my 35 and I am trying figure out if its working right. When I turn on ignition it goes to discharge even further with lights and heater motor. Then when I start the car it doesn't come up. When I unhook the output wire off the cutout relay on the gen I get 7 and half volts so gen is working. Don't know if the original works or not they cut the wire and ran it through the after market gauge. It's putting out volts why is this gauge not reading it. How do I check if gauges are bad and is it possible there is a difference in 6 and 12 volt gauges. Also at what rpm should the gen start putting out volts mine seems to have to be up around 1500 rpms.
Thanks Bob
Thanks Bob
