Bob from Northport
Any one ever install a 6 volt pos. ground alternator on a 256 V-8 Mercury-1954???
Hi Bob,Any one ever install a 6 volt pos. ground alternator on a 256 V-8 Mercury-1954???
I am installing a PowerGEN 6 volt alternator into my dad’s 1955 ford Customline. I’ve disconnected the voltage regulator wires. I was wondering if I can disconnect the wire coming off the light switch that went out to battery post on voltage regulator? Also was wondering if I can hook a wire from PowerGEN to the power side of horn relay? Any advice would be appreciated. Thank you
